Re: Steel wheel rims?
Posted by Janicholson on March 31, 2006 at 12:39:11 from (199.17.6.175):
In Reply to: Steel wheel rims? posted by kevin Ruppert on March 31, 2006 at 12:32:22:
Have a steel shop make two loops the circumference of your lug tips, wide enough to cover the lugs out of 1/2" stock. At the gap use small load binders to clamp tight. If the lug spacing is wide (more than 6") i would screw blocks of wood between lugs to prevent crushing the hoop. Welded on tabs keep it centered on the wheels.
JimN
