Re: AWD Super 6 Stuck in Reverse Gear
Posted by Rob Lockwood on April 01, 2006 at 12:27:41 from (203.220.166.52):
In Reply to: Re: AWD Super 6 Stuck in Reverse Gear posted by Redfan on March 30, 2006 at 01:29:09:
Thanks Redfan, I have removed the pin but cannot pull the gear lever out. A mate of mine suggested that if the selector is a full ball you cannot remove it. I will take your advise but and go through the pulley as this sounds a lot easier than removing fuel tank and everything else in its path. Thank you once again Redfan.
Rob
