Re: only runs with starter switch held down
Posted by John T on April 01, 2006 at 13:35:42 from (66.244.90.98):
In Reply to: only runs with starter switch held down posted by IH10020 on April 01, 2006 at 12:57:40:
IH, If its a battery powered coil ignition instead of a Magneto, I would wire the Ignition switches BAT input terminal to the load (NOT to battery/starter) side of the ammeter to serve as the input voltage source to the switch and coil. Neither side of the starter switch goes through the ammeter, so to get a true reading of amperage, loads like lights or ignition need to be powered up from the ammeters load (NOT to battery/starter) side terminal. Its possible to feed the ammeters input terminal off a starter switch on the big main input terminal where theres that big cable to the battery, but if its fed off the other (to starter) side of the starter switch, the loads (lights or ignition) only get power if the starter switch is depressed. If its a battery powered coil ignition and not a mag and the coil is hot ONLY when the starter is engaged, I also wonder where youre feeding the ignition switch from??? It needs to be fed off the ammeters load side terminal. The ignition could still work if the switch were fed off the big battery cable at the switch provided its the battery not the starter side, but its loads wouldnt be running throught the ammeter that way. Check where the ignition switch gets its input voltage??? It may be wired incorrectly !!! John T
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
