Re: H Throttle rod
Posted by RustyFarmall on April 02, 2006 at 05:11:42 from (216.248.75.135):
In Reply to: H Throttle rod posted by Elk Farmer on April 01, 2006 at 16:09:56:
That rod is nothing more than a length of cold rolled steel rod, the ends are bent and a small hole is drilled to accept a cotter pin. Should be relatively easy to make, should be about as easy to find a used rod that is still useable.
