Re: H Throttle rod
Posted by kfox on April 02, 2006 at 06:01:42 from (63.18.250.50):
In Reply to: Re: H Throttle rod posted by RustyFarmall on April 02, 2006 at 05:11:42:
Hey Rusty, you may have solid rod on your Farmall, but the 3 Hs I have all have hollow throtle rods on them. The ones I looked at in the boneyard were also hollow. The reason I had to make new ones was because someone had cut them in two down by the bellcrank on the engine head.Then they brazed a piece of solid rod across the cut when they put them back togather. I guess that was easier than un-screwing that fitting on the bell-crank. ken
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
