Re: 806 injector pump leaking
Posted by jdemaris on April 09, 2009 at 17:10:29 from (67.142.130.47):
In Reply to: 806 injector pump leaking posted by Bob O2 Martin on April 09, 2009 at 16:47:05:
All the sealing is done by one 0-ring that fits into a groove on the throttle-shaft. One on each side. Shaft comes apart into two pieces, and each piece pulls out of the pump. Usually there's not enough clearance to get the shaft all the way out on the engine side, with the pump on, but I can't say for sure on an IH 806. Same basic Stanadyne DB style pump is used on AC, Deere Ford, Oliver, etc. A complete seal kit costs around $12.
