Re: Farmall A Plow
Posted by Mark on April 02, 2006 at 17:23:00 from (172.133.1.31):
In Reply to: Re: Farmall A Plow posted by Dave BN on April 02, 2006 at 16:55:13:
Pete,
You'll always be remanded to buying a manual first...which really helps answer your question:)!
It bolts to the drawbar, which is turned backwards...in other words the open end of the U is facing rearwards. The tongue of the plow bolts to the drawbar. Hugh MacKay can tell you most anything and gladly will, call on him in the future.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
