Re: Farmall A Plow
Posted by VAJerry on April 02, 2006 at 18:10:51 from (207.78.118.7):
In Reply to: Re: Farmall A Plow posted by Mark on April 02, 2006 at 17:23:00:
The Super A plow mounts to the reversed drawbar the plow for the A has a hanger that mounts to thew 4 (2 on each side) holes on the torque tube in front of the starter. The there is a bracket that mounts to the platform to lift the plow (R) and one for the left that mounts by the left fender if you have the two way plow. These connect to a bracket on the rear of the tractor to lift the plow out of the ground. The Super A is much simpler to mount.
