Re: Super M carburator
Posted by RustyFarmall on April 03, 2006 at 05:22:00 from (199.120.81.246):
In Reply to: Super M carburator posted by Tallperson on April 03, 2006 at 05:04:05:
On the top of the carb there is a small, round brass tag. On this tag is the number of your carburetor. You need to verify that the number on your tag is the same number as that on the rebuilt carb, and it WILL be a rebuilt carb. There are NO new carbs. Also, for what it is worth to you, there is no such thing as a totally worn out carb. If you purchase the correct rebuild kit, it will include ALL the parts which normally wear out, and if you do a good job of thoroughly cleaning and adjusting, your carb will be every bit as good as it was when new.
