SA leak @ hyd pump
Posted by mikeinWA on April 03, 2006 at 09:14:01 from (207.118.8.82):
I have been plagued by a small fluid leak at the hydraulic pump of my recently restored Super A. It seems to be leaking around the bolts that hold pump body together. I did replace all gaskets etc when it went together. I am guilty of not tightening these bolts very much as all the experience I have had with gear driven pumps in the past have called for very low torque. Is this a common problem with a simple solution?
Thanks
Mike Peroni
