Re: SA leak @ hyd pump
Posted by scotty on April 03, 2006 at 11:48:09 from (199.231.49.128):
In Reply to: SA leak @ hyd pump posted by mikeinWA on April 03, 2006 at 09:14:01:
Hi Mike,
Someone on here may have proper spec on torque, but you need to be careful because this is aluminum and will strip if over tightened! Did you change the large o-ring that seals the pump body?
scotty
