Re: Farmall F-14 Kerosene Special
Posted by Farmallgray on April 03, 2006 at 17:27:20 from (205.188.116.133):
In Reply to: Farmall F-14 Kerosene Special posted by BMC-FFA on April 03, 2006 at 15:55:29:
My question is why would you want to? Kerosene isn't any cheaper than gasoline. I won't work for puttering around at shows becuase the engine has to be worked and kept very hot (almost boiling over) to vaporize the kerosene. And it will still dilute the engine oil and increase wear. And you still have to start it on gasoline to warm it up. They used kero in the old days because it was cheaper. It may be cool to try it once just to say you did, but running on kero all the time would be a pain in the....
