Re: Replaceent Super C hydraulic filler plug for a
Posted by Wayne Swenson on April 03, 2006 at 21:14:20 from (24.181.155.110):
In Reply to: Replaceent Super C hydraulic filler plug for auxil posted by lka on April 03, 2006 at 20:04:52:
If you are using 2-way cylinders, there is no need for any extra fluid.
If my memory is correct, the thread is a standard fine bolt thread; take your out & measure it for diameter with an open end wrench. 1/2" wrench = 1/2" bolt, etc. etc.
