Re: Replaceent Super C hydraulic filler plug for a
Posted by lka on April 04, 2006 at 03:28:53 from (70.179.75.114):
In Reply to: Re: Replaceent Super C hydraulic filler plug for a posted by Wayne Swenson on April 03, 2006 at 21:14:20:
Thanks for the reply. At some point it seems that even with 2 way cylinders there is more fluid needed when the cilynders are extended than when retracted because when they are extended you need to replace the volume of the cylinder shaft.
I would be getting into my high school trig but I think the volume in cubic inches would be the stroke X shaft diameter^2 * pi / 4. I haven't done the math but the cylender on both the saginaw 3 point hitch and my new hydraulic top link are sizeable and would consume a fair amount of volume if the above calculations are correct.
Does this seem right regarding the displacement of the cylinder shaft volume or am I missing something and over engineering this thing.
Lance
