Re: adjusting the governor
Posted by Nat 2 on April 04, 2006 at 06:02:21 from (64.80.108.52):
In Reply to: adjusting the governor posted by cracker on April 03, 2006 at 18:30:16:
I am pretty sure that there is no adjustment, nothing you can tweak with a screwdriver from the outside at least.
What is the problem you're having that you think you can adjust out? Most governor problems are caused by weak/broken springs and worn/broken linkages inside the governor.
