Re: 20 second H
Posted by DHB on April 04, 2006 at 07:41:54 from (69.35.147.172):
In Reply to: 20 second H posted by adding a red on April 04, 2006 at 04:28:55:
Take the screen out of the sediment bowl(s) and check for gunk up above where the screen sets. I cleaned the bowls and screenes and still had the problem, then checked again and found that area was plugged up. Good luck
