Re: 1066 Adjustments
Posted by the tractor vet on April 04, 2006 at 08:10:36 from (66.202.111.33):
In Reply to: Re: 1066 Adjustments posted by Michael Sheik on April 04, 2006 at 04:44:53:
Ok here goes get you pencile and paper ready this gets involved as it is not the same as doing a non asst. clutch , With engine off first go to the wright side of the tractor and pull the pin that works the transmission brake next you pull the pin on the Ft. clutch rod and push it back into the cylinder till you feel resistance to set the piston and hold it there next loosen the the lock nut on the rod from the pedal to the cylinder and adjust it out so that there is some resistance then lock it down , now this is the way i do it take a 3/8th bolt it will have a 9/16th head place it between the clutch pedal and the platform this set the free travel now adjust the rod from the cylinder to the clutch bellcrank so the the pin will slide in now here is where it get tricky with age and ware on these old tractors it is sort of a feel thing ya have to hold the bellcrank aganist the throw out bearing fermly and get the pin in lock all lock nuts remove the 3/8th bolt now a extra set of hands or feet in needed here . Next got to the trans brake with tractor in park and in nutral start the engine loosen the lock nut on the clevis of the transbrake rod ,push the clutch pedal to the floor and hold it there now hold the trans brake lever to the rear till it stops then see if you can Slide the pin in if not the adjuts the clevis till it will slide in then here again it is sotra a feel thing you let up the clutch pedal then add 1/2 to 1 full turn to the clevis and install the pin and hair pin lock the lock nut down . Now go back around and loosen the T/A dump valve adjusting bolt and back it out 4-5 full turns now push the clutch pedal to the floor the T/A teltail lite should be off ifit is not the back the bolt out some more then start turning it in till it just comes on then stop let the clutch pedal up and add one more turn to the adjusting bolt and hold it in that posission and lock the lock nut down . Now you are done .
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
