Re: IH 10 ft Disk ??
Posted by Janicholson on April 04, 2006 at 12:37:45 from (199.17.6.175):
In Reply to: IH 10 ft Disk ?? posted by Lou on April 04, 2006 at 07:34:42:
Tool companies make grease fitting tools that apply massive over pressure to the junk in them. (that junk is forced into the bearing but won't matter in this case). It is basically a small shaft within a tube connected to a cup that fits on/against the fitting. It is filled with oil, or grease, and hit with a hammer to hydraulically shock the trash out. They work.
JimN
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
