Re: Starter ring gear for W9
Posted by Joe Dowling on April 05, 2006 at 06:39:08 from (169.244.70.148):
In Reply to: Starter ring gear for W9 posted by daballmakes on April 05, 2006 at 05:59:41:
Replacing the ring gear is easy once you have the flywheel off
the engine. If you have an oxyacetylene torch and are good with
it, you can do it yourself. If one of the above does not apply,
take it somewhere that knows how to replace it. Basically, you
remove the old one by cutting it with the torch. THe new one is
expanded gently with heat, (heat treating oven is best, but the
torch works too), and setting it inplace on the flywheel until it
cools, and shrinks to lock it in place. I would never bother with
trying to turn an old ring gear. Not worth the hassle.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
