Re: W6 Axle Replacement
Posted by muggsw6 on April 06, 2006 at 06:56:56 from (4.158.225.37):
In Reply to: W6 Axle Replacement posted by Yugrotcart on April 05, 2006 at 15:18:17:
The seal rides on the axle. If the axle seal hasn't been leaking the wheel can be nearly impossible to remove. I'm guessing that's why it was suggested that they be replaced as a pair. Regardless, you will need to "lift the lid" off the tranny to get the bull gear removed to pull the axle.
