Re: Super M single wire
Posted by John M on April 06, 2006 at 18:29:37 from (64.53.75.223):
In Reply to: Super M single wire posted by jeffalex2 on April 06, 2006 at 15:41:34:
With some fitting and a NORMALLY OPEN oil pressure switch wire the alternator through the OP switch,no OP no drain,when the oil pressure is up,the current wqill flow.I have one piped in at the OP gauge on one of my Ms,works fine and doesnt kill the battery.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
