Re: super c hyd.
Posted by gene bender on April 07, 2006 at 01:48:37 from (66.43.221.211):
In Reply to: super c hyd. posted by m+j farms on April 06, 2006 at 18:59:10:
There are two ways to do that. You can put one in line with the pressure which is the small one by cutting it and then brazing fittings to run pressure thru the new control valve the back into the line. You can also take out the two plugs where the block attaches to the rockshaft unit and install the control valve to those two ports. You can also buy at a salvage yard the assy from the pump to the rockshaft that has the ports for a remote. You can also make a block that will bolt between the inlet on the rockshaft and the two lines coming from the pump so to run the pressure thru the control valve then into the block. I have seen it done the several ways i just described. I have one that they just made a block to bolt in and drilled and tapped it so the pressure comes out of the line thru te control valve then back into the bottom of the new block into the rockshaft assy. The easy way is just removing the two plugs at the rockshaft and going thru the control valve back into the return line which it the big. The smaller line is pressure
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
