Re: super c hyd.
Posted by Randy in NE on April 07, 2006 at 05:04:29 from (204.124.192.90):
In Reply to: super c hyd. posted by m+j farms on April 06, 2006 at 18:59:10:
This will work only if you are using a two-way cylinder. The touch control unit only holds about 3 quarts of hydraulic fluid. I tapped into the two little plugs in the manifold on the side of the touch control unit. Keep in mind that those 1/4 inch plugs are blocking ports that are only about 1/8" in size. The hydraulics work but don't get in a hurry as there isn't a large volume of fluid that can get through those ports. The major problem is going to be the fact that the touch control unit has in internal bypass. Once you move either of the levers and the rockshaft reaches its desire position the touch control unit dumps any pressure in the high pressure line and you no longer have adequate pressure to operate the remote hydraulic cylinder. What I did to get around this was to take a short lenght of 3/8" chain and run it from one of the rockshafts and one of the 3 large implement mounting bolts on the front of the tractor. I then pull that lever back and since the rockshaft can't move the touch control unit keeps high pressure in the return line from the pump. If you are not using the cylinder then just move the touch control lever forward again and that will relieve tension on the chain and the bypass will operate as normal. If you don't feel like jumping through all of these hoops then I would suggest getting the correct manifold for it. Feel free to email me if you have any questions. Randy
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
