Re: 1066 MCV telltail light - finally checked
Posted by chadd on April 07, 2006 at 05:15:25 from (155.92.31.140):
In Reply to: 1066 MCV telltail light - finally checked posted by Michael Sheik on April 07, 2006 at 04:40:29:
Don't feel stupid about the MCV bulb. It must have taken me 20 minutes staring at it scratching my head before I figured out how to get it apart. Part of it was just sheer luck, and not skill. I ran into the same problem as you, the back fell behind the dashboard. What I did is I removed the cover over the 3 auxilliary gauges. Only problem is my arm was too thick to get through the mess of wires and down where it belongs. If your arms are skinnier, try that. If not, you can do what I did. I removed the bolts from the black panel that the light is mounted into. Once they are all removed,CAREFULLY pull the bottom of the panel out from the dashboard just enough to get your hand in. You need to remember that the oil pressure gauge and coolant guage are both mounted on the top. If you pull too hard, you risk kinking the small tubing running to them. Now put the new bulb in. Now before you put it back on, there should be a spring that sits between the dash plate and the back of the light housing. If not, it fell off when it fell behind the dash. What you need to do is to push the back of the light housing against the dash plate to compress it as much as possible while simultaneously pushing the plastic lens half into the back half and once it has bottomed out against the plate, turning it clockwise(I think). If you have one person to push in the housing and another to push in the lens and turn, it makes it a lot easier, because the spring is hard to compress alone I had the front half come flying out several times. Then put in the ignition key and turn it to the run position. If it works put the bolts back in the plate and you should be set. If not, check to see if the wiring is damaged or if there is corrosion in the base or the switch if faulty down at the MCV. Hope this helps.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
