Re: what plow should I get.
Posted by Farmall 43 on April 07, 2006 at 12:15:40 from (64.109.212.38):
In Reply to: what plow should I get. posted by Andrew Z on April 07, 2006 at 12:06:21:
If I were you I would grab up that fast hitch plow in a heart beat. It definitly makes it easier to plow than with a trailer plow. It also alowas you to square off your field better. I love my fast hitch plows. I have 3. One for each tractor I plow with. 314 for the 340 and 450 and a 414 for the 400D. As for coulters I personally do not use them. If you really must have them they are readilly availible at most tractor junk yards. A few people will argue that you must have them, But even in sod I disagree. Disk it once over then plow and then disk again. This will give you a much better seed bed. Good luck and enjoy. Matt
