Re: Okay, Let's Try This
Posted by the tractor vet on April 08, 2006 at 07:56:41 from (66.202.111.37):
In Reply to: Okay, Let's Try This posted by Allan In NE on April 08, 2006 at 07:20:47:
Don't have my book setting next to me this morning but on the 310 's hard starting can be a number of things and over heating is not one of them now as for hard starting cranking pressure of the pump and tha means that the head on the pump has more clearance then it should or slow cranking speed and that means that the starter is not getting enough juice or the bushings are getting woren , injectors are not breaking at the correct pressure or spray pattern is not sprayen wright caused by carbon build up or plug tips , low compression due to bad rings or woren sleeves or the valves are down in the head to far. late timming will make her lazy . As for checking the timming there is a window on the outside of the pump and there will be a pointer inside of that window and a scribed line on the disk that will line up when ya have the timming pointer lined up with the correct timming marks on the flywheel on the right hand side on the flywheel and to adjust you remove the plate on the ft. of the timming cover on the ft. side of the pump and there are three - four bolts in the gear with slots and you place a scoket on the center nut on the injection shaft and turn . Now finding the scribbed line at times can be a bear as if the pump has been rebuilt and new parts have been put in some pump guys do not make the line real easy to see . And the only way that you can check cranking pressure is to pull the pump and now get this is to rebuild it then check as nobody will take and old pump and put it on there stand and run it as it is as they do not want to contamenate there stand with and old dirty pump.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
