Re: HELP The Plot Sickens
Posted by Allan In NE on April 08, 2006 at 15:39:35 from (148.78.243.24):
In Reply to: Re: HELP The Plot Sickens posted by old on April 08, 2006 at 12:55:34:
Took the sheet metal off and reinsulated the tube. Could sure tell that it was heat that melted the old stuff away.
Re-routed it, put the tractor all back together and then used it for two hours hauling hay and the gauge never got over mid way. But, here again, I wasn't pullin' the tractor real hard either.
We'll see how it acts next week when I spring tooth that 50 acres of alfalfa ground. That ought to make 'er snort. :>)
Allan
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
