Re: 656 Tach Reading Off
Posted by TDK on April 08, 2006 at 18:25:50 from (205.188.116.133):
In Reply to: 656 Tach Reading Off posted by Formerly PaMike on April 08, 2006 at 16:05:04:
Most places that restore antique auto guages/tachs/speedometers will also do the same for tractors, but it's pricey. I know of at least one or two if you need the phone numbers. I'd do as "vet" says and make sure you need it calibrated first.
