Re: Drain on battery - help
Posted by Bob M on April 10, 2006 at 04:44:36 from (151.190.254.108):
In Reply to: Drain on battery - help posted by BillWv on April 10, 2006 at 04:32:25:
Bill - Not to worry....that's perfectly normal!
What's happening is when you turn on the ignition it draws a couple amps from the battery. And when the battery charger is connected it senses this, then increases the current it sends to the battery to compensate for it.
Thus the extra couple amps that shows on the charger's ammeter when the ign switch is pulled out.
