Re: Farmall Pipe.s
Posted by Janicholson on April 10, 2006 at 11:34:06 from (199.17.6.175):
In Reply to: Farmall Pipe.s posted by kirk in ks, on April 10, 2006 at 11:10:31:
No offense intended, but I have no idea what you mean. Assuming you are referencing exhaust pipes, they are often customized by many owners (but) they either come out the top through a hole in the hood, or curve forward and dowm in front of then below the intake area to a muffler. Farmalls almost all are up through the hood. Later series may have exhaust pipes away from the sheet metal.
JimN
