Re: What are these levers for on my 460
Posted by Marksd on April 10, 2006 at 19:03:47 from (70.57.235.14):
In Reply to: Re: What are these levers for on my 460 posted by chadd on April 10, 2006 at 09:55:35:
Chad, thanks for the info. With the TA engage do you skip using the main clutch and then it uses the TA clutch? I was looking around today on the tractor and down by the voltage regulator on the trans there is a plate with 4 bolts. I took it off to see what it was and it looked like a clutch. When the tractor is running , not in gear, with the clucth out it spins, push the clutch in it stops. Let the clutch out and pull the TA is also stops. Does that make sense? I just wondered. Also could you tell me where to drain the trans hydraulic fluid and where to check it and fill it. Also fill it how much. Wish my service manual would hurry and get here.
