Re: Mower ? for Hugh or other mowing experts
Posted by Haas on April 10, 2006 at 19:41:35 from (12.65.18.116):
In Reply to: Mower ? for Hugh or other mowing experts posted by Paul Shuler on April 10, 2006 at 18:35:13:
My experience is with a Woods mower. I'll echo CNKS on those. As tight as you can get the belt. I use a jack to push down the belt quide to hold it while I tighten the idler pulley. I've in the past noted the same as you with the woods on a 140, streaking in the middle if the grass is high or tough. Get the belt as tight as you can, after that the only cure is to gear down, assuming you have sharp blades.
