Bleeding fuel lines
Posted by Ray in Ga. on April 11, 2006 at 16:23:29 from (68.215.209.85):
I"ve been fixing up an IH 484 for a friend who came by it when he bought a house. The previous owner left it behind. Been piddling around with it since last August replacing seals, water pump, beating out dents:-) When I started, I knew nothing about tractors or diesel engines. That became readily apparent when I told my son I was going to get some spark plugs and tune it up. When he got done laughing at me, I ran to the internet to study up:-) All this time, thought the thing has run great. Always cranks right up and I have run it for hours at a time. The other day the tractor stalled for the first time. I discovered a piece of plastic bag hanging off of the fuel float and figured that was blocking my fuel line. Also fished out a gas can funnel and cap while I was in there! I went ahead and replaced both fuel filters and bled them through the top screws. Problem is now it runs great for around 30 minutes and then dies a slow death. Sometimes it will crank back up, but will only run for a couple of minutes. I checked to see if fuel would come out of the bleed screws on both fuel filters. Nothing comes out. I tried both filters every few minutes with no luck. Then after about 15 minutes or so, the fuel started flowing again. I have traced the fuel lines looking for a fuel pump to no avail. I am beginning to think it is incorporated into the fuel injector pump, though everything I read leads me to believe there should be a separate pump somewhere. Can someone explain this system to me and tell me where the fuel pump is? How do I bleed this thing correctly, especially if I can"t find a fuel pump? The owners manual says to bleed the system, then crank up the engine. So I have to believe there is a manual way to force the air out. Or could it be something else entirely?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
