Re: Firecrater piston questions
Posted by gene bender on April 14, 2006 at 03:26:28 from (66.43.221.211):
In Reply to: Firecrater piston questions posted by Shovelman on April 13, 2006 at 15:02:51:
You mite have to go to a DIST as there is NO WAY to advance a MAG as it will fire T.D.C. then go to 36deg when it runs. The problem you mite run into i the MAG cannot be changed for advance when in start mode. I had this problem when i went to a RED POWER kit the domes were very high and it would not start with a MAG. Put a dist on the engine and starts great. Friend who was I-H mech said there was a notice from I-H when using FIRE CRATER you need a dist.
