Re: Poping out of gear
Posted by Dr.EVIL on April 14, 2006 at 08:58:15 from (216.136.115.250):
In Reply to: Re: Poping out of gear posted by JarrodS on April 13, 2006 at 22:11:49:
Jarrod - There's no "gears" in engagement in 5th gear in an H or M, they're all direct drive thru the sliding gear topshaft. The sliding 4th/5th gear engages the splines on the back end of the transmission input shaft that is separated from the top sliding shaft by the pilot bearing. There are gears in mesh like the constant mesh gears where the initial reduction from 1650 rpm to 540 rpm takes place but if there's no load on the PTO or hyd. belly pump there's no load on those gears and they shouldn't make much noise. If You have gear whine or howl in 5th gear You didn't have before You may have the top sliding shaft/pinion slightly out of the old position it ran in on the ring gear. Could also be the small pinion gears howling on the bull gears. FWIW, every M & H that has had the transmission & rearend apart that I've seen normally makes noise. As long as the oil is clean they should still run another 30-40 years. ;-)
Home
| Forums
Today's Featured Article -
Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
