Re: Carb Trouble?
Posted by Jim Broughton on April 14, 2006 at 20:38:39 from (4.255.64.252):
In Reply to: Carb Trouble? posted by purduepete on April 14, 2006 at 20:30:20:
When you hooked up the carb....did you connect the linkage to the governor? If that checks out OK...then check you needle valve settings and if that checks out...??
Good luck
Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
