Re: B valve adjustment, what happened?
Posted by Charles McNelly III on April 15, 2006 at 19:26:46 from (65.54.154.17):
In Reply to: Re: B valve adjustment, what happened? posted by El Toro on April 15, 2006 at 03:50:28:
Hi Hal,
I don"t want to argue with you but my B series Farmall tractor operators manual part # 100803R4 page 39 under valve clearance adjustment first paragraph says .014 inch measured when engine is warm. You know alot more then I do about these little tractors. I was just going by what IH printed in there manual. Thanks for the correction.
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
