Re: 330u ??'s
Posted by Janicholson on April 16, 2006 at 17:11:43 from (66.173.50.74):
In Reply to: 330u ??'s posted by Tweeter on April 15, 2006 at 19:49:17:
The throttle linkage does wear. With it turned off, and the throttle dash lever at full forward idle, find the governor control lever on the back of the gov. Remove the link from the control lever. Now move the dash lever to full throttle (last notch). Go to the governor again and see if the link is long enough to be pushing the governor control lever to full travel (align the link with the hole and see if it went as far as above. If it did not, adjust the length on the link (you may need to remove sheet metal to get at the assembly to adjust it) There are two springs and a metal bracket. Study it so that when adjusted it remains in the same tension, but moves the link as needed. If a spring is broken, replace it with a simslar hardware store spring. (they do not change the engine speed, that is inside the governor). There will be a dead zone (about 1/4-1/3 of travel at the Idle end. The above makes sure you are able to apply ful throttle. If the TA lever is pulled back and latched, and the tractor slows down about 30% but still pulls, the TA is probably OK. IF it stops with the TA pulled back, The TA is out. It should not free wheel in direct drive. If the lever does nothing, the linkage may be broken, or way out of adj. The tractor may not be going into direct at all. If it will go only about 12-13 MPH in fifth gear it is not in direct, and needs attention to the linkage at least. A manual is a must. JimN Keep us informed.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
