Re: Cub won't start
Posted by K-Mo on April 16, 2006 at 20:41:29 from (65.169.189.2):
In Reply to: Cub won't start posted by Shaun Murray on April 16, 2006 at 20:22:56:
From what you have said, I would suspect the coil may have burned up. You probably need a resistor on the power to the coil. Many 12 volt coils are not designed for 12 volt operation. In these applications, the coil receives 12 volts for a hot spark while starting and then the voltage to the coil is droppped through a resistor during normal operation.
Coils are usually labeled such as "external resistor required"
K-Mo
