Re: Cub won't start
Posted by Nat 2 on April 17, 2006 at 06:49:43 from (64.80.108.52):
In Reply to: Cub won't start posted by Shaun Murray on April 16, 2006 at 20:22:56:
REPLACE the coil and points.
Some of the responses below indicate that you need a ballast resistor, and that may mislead you to believe that all you need to do is add a ballast resistor and everything will be fine...
WRONG. The damage has been done, and the coil will not "heal" through the addition of a ballast resistor. It's broken, ruined, destroyed, damaged beyond repair. Replace it.
Since you're going to replace it anyway, get a 12V coil and skip the ballast resistor.
