Re: 300 Utility Locked Up?????
Posted by old on April 17, 2006 at 21:06:39 from (207.69.139.149):
In Reply to: 300 Utility Locked Up????? posted by Rabbitchoker on April 17, 2006 at 20:00:36:
Well I would do a couple things. I would first off fill the cylinders with tranny fluid and then as the others have said pull the starter to make sure thats not whats up with it. I would also loosen up the drain plug on the engine just to check that you don;t have any water in the oil. You should never let an engine sit for more then a month with out at least turning it over. For me thats almost a full time job but all on mine get turned over at least once a month or more. Check the web site to understand
