Re: 300 Utility Locked Up?????
Posted by Nat 2 on April 18, 2006 at 04:53:22 from (64.80.108.52):
In Reply to: Re: 300 Utility Locked Up????? posted by jeffcat on April 17, 2006 at 20:10:00:
That's a real good way to break a hole in the bell housing... Why don't you FIX the problem?
The reason the starter locks up is because it's WORN OUT. More specifically, the "Bendix end" on the starter is worn out. Pull the starter and have a look. The gear teeth will be all worn and chewed up. Look inside the starter mount hole at the ring gear. Make sure it's not all worn and chewed up too. If it is, it will need to be replaced as well.
