Re: 986 frame
Posted by Janicholson on April 18, 2006 at 13:07:01 from (199.17.6.175):
In Reply to: 986 frame posted by 4 R's on April 18, 2006 at 11:22:50:
We do not know what "welding" has been attempted, so assuming the worst! Use an angle head grinder and remove all existing weld to base metal. Do not reduce the thickness of the frame metal or bracket. Use wedges and clamps to position the frame rail onto the bracket so that it is correctly positioned. V out the area where they touch to about 2/3 of the frame thickness. Do not make a wide V (about 1/4" at the widest). I would use 5/32" E-1714 rod on AC with about 120-135 amps. Weld a root pass down from top about one inch and stop. Beat the devil out of the weld when it has just turned black with a pointed slag hammer. (this stress relieves the metal and makes it much stronger) wait about 5 minutes, and make another 1" pass starting at the bottom of the first. Again beat it to death with the hammer. Again wait five minutes then cool the weld area with air (not water) When cool repeat the process until a root pass, and three top passes are applied and beaten to death (using a 1/4" drift punch on the top passes makes your pounding less visible). Grind off spatter and paint. JimN
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
