Farmall 656 clutch
Posted by John H MI on April 18, 2006 at 18:37:21 from (205.188.116.133):
I have a 71' Farmall 656 gas, gear drive.The tractor does not have a T/A. Here's the story... after a few tugs trying to pull my pickup out of the mud, the tractor stopped in gear and made a grinding noise. I can put it in all the gears with the shifter but when u let the clutch out all it does is make a grinding noise.if u push the clutch in the noise is minimal. The PTO still works and so does the fasthitch. I pulled the inspection plate off the bottom of the bellhousing and i couldn't find any metal shavings or loose parts.. The clutch looked pretty fresh from what i could see... does this definantly sound like a clutch problem, or could it be in the linkage?? any help would be GREATLY appreciated!!
