Re: Farmall A - Starter, battery or Solenoid
Posted by old on April 19, 2006 at 18:52:37 from (207.69.139.151):
In Reply to: Farmall A - Starter, battery or Solenoid posted by plh_in on April 19, 2006 at 18:42:40:
You sort of answereds your own question. You said the battery cable gets very hot. Well most of the time a cable getting hot is one of 2 things. ! and bad cable. 2 a starter that is going bad. Either way now that you have smoked a battery cable you need to replace it. Don't buy an auto type cable becuase they just don't dut it. You need and 0 or 00 cable and then go from there
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
