Re: Farmall A - Starter, battery or Solenoid
Posted by Peabody on April 19, 2006 at 19:18:47 from (64.12.116.65):
In Reply to: Farmall A - Starter, battery or Solenoid posted by plh_in on April 19, 2006 at 18:42:40:
I don't recall letter series Farmalls having a solenoid, unless it has some sort of retrofit starter. Like Old said, I'd start with the cables and make sure ALL connections are clean, bright and tight.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
