Re: Hydraulic pump Farmall C
Posted by Peabody on April 19, 2006 at 19:29:19 from (64.12.116.65):
In Reply to: Hydraulic pump Farmall C posted by Bill WIneman on April 19, 2006 at 15:08:35:
It seems not long ago we had a similar thread. The participants were confused and perplexed trying to explain the procedure to someone who had the pump disassembled and couldn't figure it out (It's really a simple little gizmo). He finally realized that the pump gear could be pushed out from the forward section of the housing (pushing the gear shaft rearward), thus exposing the shaft oil seal seated in the housing under the gear. The o-rings keep the pump from leaking externally--the shaft seal is what keeps the fluid from draining into the oil pan. Hope this helps.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
