Re: SMTA battery drain
Posted by Bob on April 19, 2006 at 21:25:09 from (64.21.249.40):
In Reply to: SMTA battery drain posted by Hayfarmer on April 19, 2006 at 21:16:49:
First, try this. Upon shutdown, pull out the 2-wire plug to the regulator, and see if the battery still drains. If so, also disconnect the charging wire from the large output stud, and cerify that the battery DOES NOT go dead. If the battery holds it's charge, you definitely have an alternator problem.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
