Re: SMTA battery drain
Posted by Bob M on April 20, 2006 at 04:36:50 from (151.190.254.108):
In Reply to: SMTA battery drain posted by Hayfarmer on April 19, 2006 at 21:16:49:
Assuming there’s no other parasitic load when the tractor is shut down, problems gotta be with the alternator – either a failing internal regulator or a bad diode. Bob’s test below will tell you which it is.
However probably the easiest fix is to simply replace the alternator. Rebuilt 10SI ‘s are dirt cheap and available everywhere!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
