Re: Super MTA Rear Light Bracket
Posted by Dave Slater on April 20, 2006 at 06:00:36 from (205.188.116.133):
In Reply to: Super MTA Rear Light Bracket posted by Retcol on April 19, 2006 at 18:56:13:
Originals used a threaded hole it battery box that a piece of 1/2 inch pipe screwed in.Ones that came later and aftermarket had several holes several different ways.Lot of them used a 1/2 inch pipe with 2 pipe thread nuts on each side of the big hole to mount,several others used a rear light bracket like the 300 to 450 tractors used with 2 bolts used to mount. Some of the aftermarket boxes used to have so many holes in them to fit all that it looked like shotguners had used for target practice.
